查看: 587|回复: 0
AIRBFT气动避震无缝防爆气瓶磨具旋压工艺无焊缝
发表于 2020-7-26 15:30:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber seamless explosion proof gas cylinder grinding tool spinning process without welding seam
气动减震器的工作原理就是通过控制气压来改变车身高低,其包括绞牙减震器、气压控制系统和电子控制系统等。在车展或者车友聚会时,我们会经常看到很多“趴”在地上的车,很多没见过的人都会想这车怎么开啊,别担心,一键搞定你
The working principle of pneumatic shock absorber is to change the height of the car by controlling the air pressure. It includes the toothed shock absorber, air pressure control system and electronic control system. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think about how to drive this car. Don't worry. You can get it with one button
