查看: 654|回复: 0
“永不会被潮流所遗忘的霸主”奔驰W140改装AIRBFT气动避震案例介绍
发表于 2020-7-25 17:09:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The overlord who will never be forgotten by the trend" Mercedes Benz w140 refitting airbft pneumatic shock absorber
奔驰W140是奔驰S级的第七代车型,做为奔驰S级承上启下的王牌车型,他曾是世界车坛的王者,在他如日中天时,其江湖地位无人能及,相比他的继任者们,奔驰W140可以说是迄今为止最成功的S级
Mercedes Benz w140 is the seventh generation of Mercedes Benz S-class. As the trump car connecting the preceding and the following, Mercedes Benz w140 was once the king of the world's automobile industry. When he was at its zenith, its status in the world was unmatched. Compared with his successors, Benz w140 can be said to be the most successful S-class so far
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
