查看: 714|回复: 0
完美车型奥迪S5改装AIRBFT气动避震悬挂优势
发表于 2020-7-25 16:48:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect Audi S5 modified airbft pneumatic suspension advantages
AIRBFT专用气囊:
Airbft special airbag:
Like airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue times 3 million to 5 million times, normal use of 3-5 years no problem! All the airbags are tested by strict testing equipment to test the pressure, and then they can be sold together! The clamp part of the leather bag is compressed by high-pressure locking equipment, and the normal pressure test is at 200psi, explosion-proof! The outer layer of the leather bag is protected by anti-corrosion, rain, sand and dust resistant materials! Give you the safest protection
