改装气动避震的使用寿命期限路虎揽胜运动以身试法
Life span of modified pneumatic shock absorbers
在豪华品牌当中,路虎是一个非常特别的存在。专业越野车出身的背景注定了路虎不会像竞争对手们那样重点强调享受,而是热衷于挑战各种极限、征服各种不可能,以展示其强大的全地形能力。 在外观构型方面可圈可点,整个车的侧面我最喜欢。前脸加入未来科技语言,让人总想多看几眼,感觉雨刮器和车前窗很搭配,像一对情侣。尾部的线条给人有一种时髦的感觉,车轮还有尾灯的升级套件,我相信许多驾驶者都会愿意升级。整体来说,美艳的造型设计总能成功吸引路人的眼球。
Land Rover is a very special presence among luxury brands. The background of professional off-road vehicle is destined that Land Rover will not emphasize enjoyment as much as its competitors do, but is keen to challenge various limits and conquer various impossibilities to demonstrate its strong all terrain capability. Impressive in appearance and configuration. I like the side of the whole car best. The future technology language is added to the front face, which makes people always want to see more. It feels that the wiper and the front window are very matched, like a couple of lovers. The lines on the tail give people a sense of fashion. The upgrade kit for wheels and tail lights, I believe many drivers will be willing to upgrade. On the whole, beautiful modeling design can always successfully attract the attention of passers-by.
气动避震的组成部分分为控制系统和气动避震桶身两大类!
三段记忆功能:车主可以自行的设置高位,正常,低位三个不同的高度模式,通过按键1 2 3 一键升到或者是降到适合当前路况的高度,高速时可以降到1档低位行驶,降低重心来增强车子的稳定性和降低风阻,还能从一定程度上节省燃油,城市或者是乡村可以升到2档正常的高度来行驶,可以应付大部分路况,如果遇到非常差劲的路况的话可以把车子升到3档,来提高通过性,从最低升到最高大概有12公分左右的行程!3个不同高度的档位可以随时的快速切换!智能补气和智能调节车子水平:其实这两个功能大概的作用都是一样的,比如说车身本来是水平的高度,后排座椅坐上来一个胖子,后边的高度就会降低,这个时候电脑会检测到后边的高度变化,会在不到一秒的时间内做出反应,往后边的两个气囊里边充气来保持车身水平!
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
Three segment memory function: the car owner can set three different height modes: high position, normal position and low position by pressing the key 1, 2, 3 One button up or down to the height suitable for the current road conditions, high speed can be reduced to the first gear, low driving, reduce the center of gravity to enhance the stability of the car and reduce the wind resistance, but also to a certain extent save fuel. The city or the countryside can rise to the second gear normal height to drive, can deal with most of the road conditions, if encounter very bad road conditions, you can raise the car to 3 Gear, to improve the trafficability, from the lowest to the highest about 12 cm journey! Three gears of different heights can be quickly switched at any time! Intelligent air replenishment and intelligent adjustment of vehicle level: in fact, the functions of these two functions are the same. For example, the body height is originally horizontal. If a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change at the rear, and respond in less than one second. The two air bags at the back will be inflated to maintain it Body level!
