查看: 728|回复: 0
“百看不厌”高尔夫4改装AIRBFT气动避震低趴案例 完美姿态展现
发表于 2020-7-24 16:53:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Never tire of watching" Golf 4 refitting airbft pneumatic shock absorber low prone case
高尔夫4之所以叫mk4是因为MK即MARK的意思,类似第几代的意思,是车厂的代码。Mk4也是第一代在国内生产的高尔夫,也就是说,高尔夫4代是高尔夫国产的第一代车型,所以被国内的高尔夫迷们奉为经典。Mk4在技术上改进得并不多,但其里程碑意义在于把高尔夫这一平台的通用性做到了新的高度,这也解释了高尔夫4为什么叫mk4。
Golf 4 is called MK4 because MK means mark, similar to the meaning of several generations, is the code of car factory. MK4 is also the first generation of golf produced in China. In other words, golf 4 is the first generation of golf made in China, so it is regarded as a classic by golf fans in China. MK4 has not improved much in technology, but its milestone is to make golf a platform of versatility to a new height, which also explains why Golf 4 is called MK4.
『气动减震器,能够轻易改变车身高度』李洋
IRBFT专车专用皮囊,所采用的天然胶成分比轮胎天然胶成分还要多!单次疲劳次数5百万次到8百万次,正常使用3-5年一点问题没有!都是经过严格的测试设备来进行试压 饱压才能出售!在皮囊的卡箍环节经过高压力的锁紧设备,皮囊外层都有防腐蚀 防雨水 防沙尘 耐磨材料层层保护!
Irbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue 5 million times to 8 million times, normal use of 3-5 years, no problem! After strict testing equipment to test pressure, full pressure can be sold! Through high-pressure locking equipment, the outer layer of the leather bag is protected by anti-corrosion, rainproof, sand and dust resistant materials!
