查看: 797|回复: 0
大众迈腾B6旅行版改装AIRBFT气动避震秀出低姿态
发表于 2020-7-24 16:26:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen maiteng B6 travel version refits airbft to show low profile
在道德礼义的领域,贪念,常被贬低为诸恶之渊源。但是,换个角度来想,人类的进步,不也常由贪念造就而来?对我而言,大众迈腾B6旅行版就是起於贪念结为善果的最佳明证!不同于房车与SUV的极端定位,有人偏偏就是贪心,既喜爱房车的操控与流线外观,却又对SUV的承载机能难以忘怀,鱼与熊掌兼得的贪念,造就了旅行车的诞生。
In the field of morality and propriety, greed is often belittled as the origin of all evils. However, from a different perspective, is not human progress often caused by greed? As far as I'm concerned, the B6 Travel Edition is the best proof that greed turns into good results! Different from the extreme positioning of RV and SUV, some people are greedy. They not only like the operation and streamline appearance of RV, but also have unforgettable bearing function of SUV. The greedy desire of having both fish and bear's paw has created the birth of station wagon.
如果说低趴风格改装已成风,大家对此已经见怪不怪的话,那么相信接下来的这台本田奥德赛一定会非常引人眼球,继气动悬挂成为大家改装的主流之后,极端的“恐高症”患者们都开始往更加极端的方式去改装,低趴的姿态与硕大尺寸的轮毂完全不能满足他们的胃口,所以视觉效果十分夸张的宽体车身就成为了他们的改装方向。
If it is said that low lying style refitting has become a fashion, and everyone has seen it all the time, I believe that the next Honda Odyssey will be very eye-catching. After pneumatic suspension has become the mainstream of everyone's modification, the extreme "acrophobia" patients begin to modify in more extreme ways. The low lying posture and large size wheel hub can not meet their needs Appetite, so the visual effect is very exaggerated wide body body has become the direction of their refitting.
