查看: 836|回复: 0
奔驰S级商务改装AIRBFT气动避震魅力引领低趴潮流
发表于 2020-7-24 16:00:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz S-class business refitting airbft pneumatic shock absorbers lead the low lying trend
奔驰S级四个字的影响力已无需我多说,它代表多少人心中的梦想,代表着几代人的记忆。奔驰S级更加受成功人士追捧,奔驰其品牌就给人一种豪华商务的气息,定位更加高端,也使得奔驰S级被誉为是成功人士的象征。
I don't need to say more about the influence of Mercedes Benz S-class. It represents the dreams of many people and the memory of generations. Mercedes Benz S-class is more sought after by successful people. Its brand gives people a sense of luxury business, and its positioning is more high-end. It also makes Mercedes Benz S-class known as a symbol of success.
