查看: 786|回复: 0
玲珑姿态 --宝马Z4改装AIRBFT气动避震悬挂案例分享
发表于 2020-7-24 15:34:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Exquisite posture -- case sharing of BMW Z4 refitting airbft pneumatic suspension
玩避震的朋友都知道气动避震是最昂贵的,同时也是最娇贵的。
但是它带来的随时升降的乐趣一直是我们津津乐道的话题。
相对于绞牙避震的机械调整,不能随时调整车身高度来应付各种路况,气动避震就能随时调整车身高度的完美姿态来走崎岖的路面。
Friends who play shock absorbers know that pneumatic shock absorbers are the most expensive and the most delicate.
But it brings the fun of rising and falling at any time, which has always been our favorite topic.
Compared with the mechanical adjustment of the hinge suspension, the height of the body can not be adjusted at any time to cope with various road conditions. Pneumatic shock absorber can adjust the height of the body at any time to walk on the rough road.
AIRBFT专用气囊:
Airbft special airbag:
