查看: 991|回复: 0
“超凡魅力”奥迪RS3改装AIRBFT气动避震悬挂案例分享
发表于 2020-7-24 15:16:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Extraordinary charm" Audi RS3 refitting airbft pneumatic suspension case sharing
但在我印象中,运动驾驶应该是需要驾驶员全神贯注去驾驶,把身上每一寸肌肉和脑里每一条神经都紧绷去驾驭一台车。所谓的“这台车很运动”应该是指驾驶一台车就像运动一样,带有竞技的味道,是对司机的一种自我挑战。
带着这个疑惑和不解我去试驾了最新的两台奥迪的高性能钢炮:RS3。
But in my impression, sports driving should require the driver to concentrate on driving, and put every muscle in the body and every nerve in the brain tight to drive a car. The so-called "this car is very athletic" should mean that driving a car is like sports, with the taste of competition, which is a kind of self challenge to the driver.
With this confusion and perplexity, I went to test drive the latest two Audi high-performance steel guns: RS3.
在改装界不论从早前上市国产第一代的GD车型,还是现在的GE车型都是一台深受大家喜爱的热门小车,改装风格更是从性能范儿、VIP到现如今大热的HellaFlush都是一把好手。提到HellaFlush,这种主要以降低车身和轮毂、轮胎外延与轮眉外延齐边的感觉为主的改装,同样是近年来十分受欢迎的一种比较“外貌协会”的风格,由于其对车型、颜色等并不像传统改装风格那样有较多限制,因此深受全球很多年轻人的追捧,以此彰显自己的个性与时尚品味。
In the field of refitting, whether from the first generation of domestic GD model which was launched earlier, or the current Ge model, it is a popular car loved by everyone. The refitting style is from performance style, VIP to Hella flush, which is now very popular. Referring to hellaflush, this kind of refitting mainly focuses on reducing the feeling of body and wheel hub, tire extension and wheel brow extension. It is also a popular "appearance Association" style in recent years. Because it does not have more restrictions on the model and color as the traditional modification style, it is sought after by many young people around the world to show their personality And fashion taste.
既然是HellaFlush首先就是要降低身段,将原本高高在上的车身变成趴在地下最好。而趴在地下无非两种:绞牙避震和气动悬挂避震,而绞牙避震虽然能够降低车身但是想要达到气动悬架的效果还是有不小难度,更何况绞牙避震对于现如今中国道路遍地的“炮弹坑”来讲实在是一种煎熬。至于气动则可以通过压缩机将压缩空气输送到每个避震的气囊中来进行高低调节,以达到趴在地上的效果。气动悬挂更是HellaFlush拥簇者们的最爱,所以ACCU AIR出品的气动避震替换了原有的避震顺利进入低趴一族!
Since it's Hella flush, the first thing to do is to lower the body height and turn it into the best one to lie on the ground. There are no more than two kinds lying on the ground: winch shock absorber and pneumatic suspension shock absorber. Although the winch suspension can reduce the body, it is still difficult to achieve the effect of pneumatic suspension. What's more, it is a kind of torment for the "Bomb pit" all over the road in China nowadays. As for the pneumatic system, the compressed air can be delivered to each shock absorber air bag by the compressor to adjust the height, so as to achieve the effect of lying on the ground. Pneumatic suspension is the favorite of Hella flush fans, so accu air's pneumatic shock absorber has replaced the original shock absorber and successfully entered the low lying family!
气动悬架避震一直被大家误解为只会升降高度而牺牲驾驶感受的避震,其实不然。ACCU AIR出品的这套气动避震并没有想象中轻飘的感觉,在直线行驶时与绞牙避震有着接近的回弹韧性,但是在弯道中则会表现出弱于绞牙避震的支撑性,不过并不会出现很夸张的侧倾。这样的行驶表现,一定会让更多的人喜欢上这种随时升降的感觉。而HellaFlush更是一种没有车型界限的改装,只要你喜欢都可以创造出独一无二的你!
Pneumatic suspension has always been misunderstood as a kind of shock absorber that can only lift the height and sacrifice the driving experience. In fact, it is not. This set of pneumatic shock absorbers produced by accu air doesn't have the feeling of lightness as imagined. It has the similar resilience and toughness with the hinge suspension when driving in a straight line, but it will show less support than the hinge suspension in the curve, but there will not be a very exaggerated roll. This kind of driving performance will certainly make more people like the feeling of lifting at any time. And hellaflush is a kind of refit without model boundary, as long as you like, you can create a unique you!
