查看: 736|回复: 0
AIRBFT气动避震核心配件之一不锈钢材质O型圈密封方便实用稳定耐用
发表于 2020-7-24 14:49:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
One of the core parts of airbft pneumatic shock absorber is made of stainless steel O-ring, which is convenient, practical, stable and durable
