查看: 708|回复: 0
大众速腾改装AIRBFT气动避震低姿态走起 炫酷造型设计
发表于 2020-7-21 11:24:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen fasten refitted airbft pneumatic shock absorber, cool modeling design with low attitude
The third kind of spring is better than any other kind of spring.
The fourth suspension on the body can be modified independently by adjusting the depth of the rear suspension to produce different effects.
