查看: 962|回复: 0
年轻人的最爱--本田欧版思铂睿改装AIRBFT气动避震低趴案例
发表于 2020-7-21 10:32:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Young people's favorite -- the case of Honda's European version of sparrow refitting airbft pneumatic shock absorber
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.
Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
AIRBFT专用气囊:
Airbft special airbag:
