查看: 657|回复: 0
“成就人生主角”奔驰C级改装AIRBFT气动避震低趴案例 自动升降模式
发表于 2020-7-21 09:47:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Leading role in life" Mercedes Benz C-class refitting airbft pneumatic shock absorber low prone case automatic lifting mode
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
Oil was surging in the blood
If you are not so ordinary
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston And the resulting pressure difference to achieve the movement of the piston rod. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
