查看: 767|回复: 0
‘风华绝代’现代菲斯塔改装AIRBFT气压避震经典姿态案例
发表于 2020-7-20 11:56:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study on the modification of airbft pneumatic shock absorbers by modern Festa
无论从任何角度来说,北京现代菲斯塔是那种科技达人或者网红们所热衷的,虽然那些隔三差五喜提玛莎拉蒂的面膜微商们未必能真的买得起补贴后菲斯塔。这不是那种一眼看上去就很惊艳的车,事实上我相信北京现代也从来没有想让它成为类似于现代N系列那样可以直接冲击视觉的车型,但它是那种让你想多看几眼,而且越看越有味道的邻家女孩一般的车型。
From any point of view, Beijing's modern fester is the kind of car that technology people or net red people love. Although those who are happy to mention Maserati's mask makers may not really be able to afford subsidies, Festa is not a real master. This is not a car that looks amazing at a glance. In fact, I believe Beijing Hyundai has never wanted to make it a visual impact car similar to Hyundai's n series, but it is the kind of car that makes you want to see more, and the more you look at it, the more you look at it, the more you look at it, the more you look at it, the more you look at it.
