查看: 758|回复: 0
“老有所依”奔驰S124精彩改装来袭 气动悬挂的经典传承
发表于 2020-7-20 10:21:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Excellent refitting of Mercedes Benz S124
大家到现在可能已经将多数的奔驰车都安上了“大奔”这个名号,但真的是它旗下所有车都能够称得起这个名号吗?并不是,如果严格意义上来看,它其实是有着一定门槛的,需要它的定价在某条水平线之上,其中奔驰S级才是真正有能力拿下这个称号的一者。
By now, we may have put most Mercedes Benz cars on the name of "Big Ben", but is it true that all its cars can be called this name? No, in a strict sense, it actually has a certain threshold. It needs to be priced above a certain horizontal line, and the Mercedes Benz S-class is the one who can really win the title.
空气悬挂,对于恩多车友来说还是挺陌生的,因为只有像路虎,奔驰还有一些高端的超级跑车才配备的空气悬挂!装备空气悬挂的都可以主动或者是自动的来调节车身的高低,从而降低或升高底盘离地间隙,以增加高速车身稳定性或复杂路况的通过性!
Air suspension, for ENDOR car friends is still very strange, because only like Land Rover, Mercedes Benz and some high-end super sports cars are equipped with air suspension! Equipped with air suspension can be active or automatic to adjust the height of the body, so as to reduce or increase the chassis ground clearance, in order to increase the stability of high-speed body or the trafficability of complex road conditions!
不过现在在改装圈里比较流行的一种改装方法,叫做气动避震,其实原理就是和空气悬挂是同宗!都是通过控制代替螺旋弹簧的空气弹簧内的气压来实现车子底盘的升降功能!这种改装的方法多以境地车身姿态为主!这就是改装的气动避震和空气悬挂最根本的差别,因为“一低遮百丑,百改降为先”下面的这台改装的奔驰S124就是一个很直观 的案例,但是气动避震改装的低姿态并不是人人都喜欢,在这里就是仁者见仁,智者见智了!
But now in the refit circle more popular a modification method, called pneumatic shock absorber, in fact, the principle is and air suspension is the same family! It is through the control of the air pressure in the air spring instead of the coil spring to realize the lifting function of the car chassis! This method of refitting is mainly based on the body posture of the situation! This is the most fundamental difference between the modified pneumatic shock absorber and the air suspension, because the modified s124 is a very intuitive case, but the low attitude of pneumatic shock absorber modification is not everyone's favorite. Here, different people have different opinions!
气动避震改装现在在国内已经成为一种潮流,玩车的人几乎人人都知道气动避震,但由于价格和产品稳定性让很多人望而却步,价格高是因为我们为保证产品质量,多数的配件采用国外进口,但是说在使用过程中出现的一些质量问题主要是由三个原因引起,一是安装环节导致,气动避震一定要找专业的安装人员进行安装调教,否则会因安装位不准确对产品造成损害、二是没有正确的使用和保养、三也是最少见的,是产品配件自身出的质量问题,如气泵衰竭,电脑不稳定等因素。所以气动避震的安装使用一定要严格按照生产厂家的要求来进行安装。那么都有哪些车型可以改装气动避震悬挂,在国内AIRBFT气动悬挂应该是车型最全的一个品牌,几乎覆盖所有车型,新车也可快速开发定制.
Pneumatic shock absorber refitting has become a trend in China. Almost everyone who plays with cars knows pneumatic shock absorbers. But because of the price and product stability, many people are deterred. The high price is because we import most of the accessories from abroad to ensure the product quality. However, some quality problems in the use process are mainly caused by three reasons. One is safety Due to the installation process, we must find professional installation personnel for installation and adjustment. Otherwise, the product will be damaged due to inaccurate installation position. Second, there is no correct use and maintenance. Third, it is the most rare. It is the quality problems of product accessories themselves, such as air pump exhaustion, computer instability and other factors. Therefore, the installation and use of pneumatic shock absorber must be in strict accordance with the requirements of the manufacturer. In China, airbft pneumatic suspension should be a brand with the most complete models, covering almost all models. New cars can also be developed and customized quickly
