查看: 707|回复: 0
粉色浪漫宝马M4改装气动避震低趴案例 精彩分享
发表于 2020-7-20 09:49:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Pink romantic BMW M4 refitting pneumatic shock absorber low lying case
宝马M4改装AIRBFT气动避震案例 尽情享受 。宝马M4 这辆车不仅看起来是宝马,开起来也是宝马。对很多顾客来说,这才是最重要的。开宝马享受的不仅是品牌而且和驾驶感也有很大的关系。宝马M4低姿态改装风格案例分享!
BMW M4 modified airbft pneumatic shock absorber case to enjoy. The BMW M4 is not only a BMW, but also a BMW. For many customers, that's what matters. Driving BMW not only enjoys the brand, but also has a lot to do with the driving feeling. BMW M4 low profile modification style case sharing!
