查看: 638|回复: 0
“国民轿车”高尔夫7改装AIRBFT气动避震低姿态
发表于 2020-7-19 16:30:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"National car" Golf 7 refitted with airbft pneumatic shock absorber low attitude
大众汽车在中国的市场占有率,想必买过车子的人都知道,而大众旗下比较亲民的两厢车当属高尔夫了,polo显得有些档次不够,高尔夫自然是大众车迷、两厢爱好者的必选。高尔夫正是因为凭借市场上的独特地位,所以正逐渐发展为街车,另外一方面正是因为它多,所以改装高尔夫成为追求个性,与众不同的必走之路。
The market share of Volkswagen in China must be known to all those who have bought a car. The hatchback of Volkswagen which is more close to the people is golf. Polo seems to be a little inferior. Golf is naturally a must for Volkswagen fans and hatchback enthusiasts. Golf is precisely because of its unique position in the market, so it is gradually developed into a streetcar. On the other hand, it is because of its many, so refitting golf has become a must to pursue personality and be different.
第一次看到气动避震改装的车子到现在深深陷入其中不能自拔,也是经历了很多的曲折!也学习到了不少关于气动避震改装的知识!
For the first time, I saw the car refitted with pneumatic shock absorber, and now I am deeply trapped in it and have experienced many twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
