查看: 954|回复: 0
美式豪华当家之作-别克君威改装AIRBFT气动避震低趴案
发表于 2020-7-19 15:54:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
American luxury masterpieces - Buick Regal refitted airbft pneumatic shock absorber low lying case
谈到美系车,就该说说上汽通用的别克,说到别克,那就该提起君威!别克君威的定位在英朗和君越之间,属于中高端的轿车,一般以舒适人性化,动力澎湃著称,而且别克君威是纯系美系车,一直是商务人士的最爱!而别克君威更是以运动为特点,舒适为辅,虽说运动中级车市场比较小众,但是新别克君威依旧诚意满满!
When it comes to American cars, we should talk about SAIC GM's Buick. When it comes to Buick, we should mention Regal! Buick Regal is positioned between yinglang and lacrosse. It belongs to medium and high-end cars. Generally, Buick Regal is famous for its comfort, humanization and surging power. Moreover, Buick Regal is a pure American car, which has always been the favorite of business people! Buick Regal is characterized by sports, comfort as a supplement, although the sports intermediate car market is relatively small, but the new Buick Regal is still full of sincerity!
正所谓一低遮百丑,这几年HF改装火遍大街小巷气动减震,也是一夜变身改装界网红,话说这是个什么
东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器螺旋弹簧+减震筒形式原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现,嗯!就是这么自信!
As the saying goes, "one low covers a hundred ugliness". In recent years, HF retrofitting has been popular in the streets and alleys, and it has also changed into an overnight modification industry. What is this
What about things? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system. It is actually similar to the air pressure reduction system The principle of shock absorber is very similar to that of common shock absorber coil spring + shock absorber tube, except that by changing the volume of air chamber (up and down direction), the distance between the body and the ground can be adjusted and the soft and hard characteristics can be changed to a certain extent. In addition, the size of ventilation hole can be changed by the motor to adjust the attenuation force of the shock absorber. Therefore, the air shock absorber can often provide better performance table Now, um! So confident!
气动避震改装现在在国内已经成为一种潮流,玩车的人几乎人人都知道气动避震,但由于价格和产品稳定性让很多人望而却步,价格高是因为我们为保证产品质量,多数的配件采用国外进口,但是说在使用过程中出现的一些质量问题主要是由三个原因引起,一是安装环节导致,气动避震一定要找专业的安装人员进行安装调教,否则会因安装位不准确对产品造成损害、二是没有正确的使用和保养、三也是最少见的,是产品配件自身出的质量问题,如气泵衰竭,电脑不稳定等因素。所以气动避震的安装使用一定要严格按照生产厂家的要求来进行安装。那么都有哪些车型可以改装气动避震悬挂,在国内AIRBFT气动悬挂应该是车型最全的一个品牌,几乎覆盖所有车型,新车也可快速开发定制.
Pneumatic shock absorber refitting has become a trend in China. Almost everyone who plays with cars knows pneumatic shock absorbers. But because of the price and product stability, many people are deterred. The high price is because we import most of the accessories from abroad to ensure the product quality. However, some quality problems in the use process are mainly caused by three reasons. One is safety Due to the installation process, we must find professional installation personnel for installation and adjustment. Otherwise, the product will be damaged due to inaccurate installation position. Second, there is no correct use and maintenance. Third, it is the most rare. It is the quality problems of product accessories themselves, such as air pump exhaustion, computer instability and other factors. Therefore, the installation and use of pneumatic shock absorber must be in strict accordance with the requirements of the manufacturer. In China, airbft pneumatic suspension should be a brand with the most complete models, covering almost all models. New cars can also be developed and customized quickly
