查看: 711|回复: 0
“时尚改装风”十代思域改装空气避震悬挂低趴风格
发表于 2020-7-19 15:42:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of "fashionable refitting style" civic modified air suspension low lying style
"思域一改装,新郎穿西装",思域系列车子,就像美人坯子一样,稍稍化妆,就会有天翻地覆的变化。上图改装后的思域,就像高级跑车一样雷厉风行,蓝色的外观,配上湛蓝的天空,绝对称得上是一道亮丽的风景线。
       不知从什么时候开始,思域变成了车界泰日天的形象,
      上怼百万豪车,下怼紧凑小钢炮,更被冠予“超跑”的称号。
      也不知从什么时候开始,只要是新出的A级车型都要拿出思域来对比对比,
      诸如MG6,领克03,菲斯塔这些运动轿跑。
      比完外观比空间,比完空间比内饰,比完内饰比动力。
      最后得出结论-思域超一切,拥有思域你就拥有豪车的所有期望!
"Once the civic is refitted, the groom will wear a suit." civic series cars, like the beauty body, will have earth shaking changes with a little make-up. The modified civic, like a high-end sports car, is as vigorous as a high-end sports car. With its blue appearance and blue sky, it is definitely a beautiful scenery.
I don't know when it began to become the image of TAIRI Tian in the car industry,
It has been awarded the title of "super running" because it has connected millions of luxury cars on the top and compact steel guns on the bottom.
I don't know when to start. As long as it's a new A-class model, it's necessary to take civic for comparison,
Such as MG6, link 03, festa, these sports car run.
Compare the appearance with the space, compare the space with the interior, compare the interior with the power.
Finally come to the conclusion - Civic beyond everything, with civic you have all the expectations of luxury cars!
"Before we start the topic, let's first talk about what is the use of pneumatic shock absorbers and what are the benefits? But it's definitely not to let the car rise and improve the off-road performance.
