查看: 753|回复: 0
现代雅科仕气动避震改装 AIRBFT气动避震代理分享
发表于 2020-7-18 11:28:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modern yakos pneumatic shock absorber refitting airbft pneumatic shock absorber agent sharing
雅科仕给人第一感觉是够大气、豪华。不愧是APEC峰会期间成员国领导人的专用乘坐车和许多韩国驻外高官使节的配用车。现代雅科仕在韩国被尊称为百年世纪(Centennial),代表着韩国汽车制造工业的最高水平。
The first feeling of yakos is that it is grand and luxurious. It is worthy of being a special ride for leaders of Member States during the APEC summit and a vehicle for many senior Korean officials and envoys. Hyundai yakos is honored as Centennial in Korea, representing the highest level of Korean automobile manufacturing industry.
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston The pressure difference between the piston rod and the piston rod is achieved. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
