查看: 1140|回复: 0
奔驰GLC改装AIRBFT气动避震低姿态成功案例
发表于 2020-7-18 10:08:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Successful case of refitting Mercedes Benz GLC into airbft aerodynamic shock absorber with low attitude
玩避震的朋友都知道气动避震是最昂贵的,同时也是最娇贵的。
但是它带来的随时升降的乐趣一直是我们津津乐道的话题。
相对于绞牙避震的机械调整,不能随时调整车身高度来应付各种路况,气动避震就能随时调整车身高度的完美姿态来走崎岖的路面。
我们先从它的工作原理来入手,气动避震就是通过气压来控制车身高度的避震器,通过气压来控制改变车身的高低。
它的构成包括弹性橡胶气囊减震器、气压控制系统、后备厢的储气罐、电子控制系统等等。
根据改装的功能,分为避震筒和控制器两个部分。
用绞牙桶身来改气包,用气包来替换绞牙避震的弹簧部分,这是比较极端姿态的玩法。很多绞牙玩家最更换绞牙避震后,如果去购买气动避震的话,原来的绞牙避震就浪费了。
Friends who play shock absorbers know that pneumatic shock absorbers are the most expensive and the most delicate.
But it brings the fun of rising and falling at any time, which has always been our favorite topic.
Compared with the mechanical adjustment of the hinge suspension, the height of the body can not be adjusted at any time to cope with various road conditions. Pneumatic shock absorber can adjust the height of the body at any time to walk on the rough road.
We start from its working principle. Pneumatic shock absorber is a shock absorber that controls the height of the body through air pressure, and changes the height of the body through air pressure.
It consists of elastic rubber airbag shock absorber, air pressure control system, air tank in the rear compartment, electronic control system and so on.
According to the function of refitting, it is divided into two parts: shock absorber and controller.
It is a more extreme way to change the air bag with the twist tooth barrel body and replace the spring part of the hinge tooth shock absorber with the air bag. If you buy pneumatic shock absorbers after you replace them, you will waste the original denture shock absorbers
最后一个方法的可靠性比较高,而且简单直接。
要去购买品牌的避震筒身,它在出厂时,就已经是一套避震筒身了,密封性是非常好的。控制系统在市面上的选择也是五花八门,气泵、电磁阀、控制单元、气罐已经不再神秘。根据不同种类和功能可以分成很多种,通过在车内的按键来控制升降,这是安装车内的控制系统,升降过程是前升前降,后升后降。
遥控升降是在前面的基础上,增加一套遥控系统,可以用遥控来升降车身高度,也是前升前降,后升后降。
带有记忆系统的控制就比较高大上了,在遥控的基础上,四个轮胎可以实现独立升降,还有记忆功能,就是记忆气压数值来换算车身高度。
这三种方法都是根据气压的数值来判断车身高度,属于气压记忆,都要安装一套气压表,在安装气压表一定要注意它的密封性。
目前最高级的就是机械记忆,它是靠高度传感器来记忆车身高度,你是一个人开车的状态,气压记忆的轮胎气压数值正常行驶是80。
如果满员的状态下,这个数值就可能上升到100,那么轮胎的高度就会降低,在行驶中就会造成托底。
没有对高度及时纠正,就会磨蹭叶子板和内衬,这是气压记忆的一个缺陷。
机械记忆会一直记忆车身的高度,即使我们的车身重量发生了变化,电磁阀会根据电脑系统的分析,反馈指令。
来增加气压,控制相应的车身高度,让车身高度一直保持在记忆下。
在你拐弯时和侧倾时,它也会检测侧倾轮的气压,补充进来,让我们的车身一直保持在正常的姿态。
可以根据我们的驾驶习惯来设定灵敏度,这是非常人性化的。
还有一些控制器有WIFI模块,就能用手机软件来控制,在打火的情况下,实现记忆和四轮独立升降,在熄火状态下,可以记忆调节高度。
在汽车外,就能实现对汽车高度的调整,可玩性非常高
The last method is more reliable and simple.
If you want to buy a brand shock absorber body, it is already a set of shock absorber body when it leaves the factory, and its sealing is very good. The choice of control system in the market is also multifarious, air pump, solenoid valve, control unit, air tank is no longer mysterious. According to different types and functions, it can be divided into many kinds. Through the buttons in the car to control the lifting, this is the control system installed in the car. The lifting process is front up, front down, rear up and back down.
Remote lifting is based on the front, adding a set of remote control system, you can use the remote control to lift the body height, which is also the front up and down front, the rear up and back down.
The control system with memory system is relatively large. On the basis of remote control, the four tires can realize independent lifting and lowering, and the memory function is to memorize the air pressure value to convert the body height.
These three methods are based on the value of the air pressure to determine the height of the car body, belonging to the air pressure memory, all need to install a set of barometers, when installing the barometer, we must pay attention to its sealing.
At present, the most advanced is mechanical memory, which uses the height sensor to memorize the body height. When you are driving alone, the tire pressure value memorized by air pressure is 80 when driving normally.
If it is full, this value may rise to 100, then the height of the tire will be reduced, which will cause undercarriage during driving.
If the height is not corrected in time, the blade and lining will be tardy, which is a defect of barometric memory.
Mechanical memory will always remember the height of the body, even if our body weight has changed, the solenoid valve will feed back the command according to the analysis of the computer system.
To increase the air pressure and control the corresponding body height to keep the body height in memory.
When you turn and roll, it also detects the air pressure of the roll wheels and adds it to keep our body in a normal posture all the time.
Sensitivity can be set according to our driving habits, which is very user-friendly.
There are also some controllers with WiFi module, which can be controlled by mobile phone software. In the case of ignition, memory and four-wheel independent lifting and lowering can be realized. In the flameout state, the height can be adjusted by memory.
Outside the car, you can adjust the height of the car, which is very playable
