查看: 1056|回复: 0
‘一往无前’保时捷帕拉梅拉改装AIRBFT空气悬挂让姿态更强大
发表于 2020-7-18 09:49:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Go all the way" modified airbft air suspension for stronger posture
Pneumatic shock absorber is a more precise part. Different from the original shock absorber, there is an elastic rubber air bag on the pneumatic shock absorber. The working principle of the elastic rubber air bag is to fill the sealed pressure cylinder with inert gas or oil-gas mixture, so that the pressure in the chamber is several times or dozens of times higher than atmospheric pressure. The cross-sectional area of piston rod is smaller than that of piston The pressure difference between the piston rod and the piston rod is achieved. Pneumatic shock absorbers are not suitable for driving on various complicated road conditions. Long term driving on bumpy roads will lead to chronic air leakage, unstable air pressure, temperature rise in the air tank, and eventually lose the accuracy of pneumatic adjustment.
