查看: 786|回复: 0
“不一样的野马”气动避震悬挂改装姿态路线的魅力
发表于 2020-7-17 13:05:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Charm of refitting attitude route of "different Mustang" pneumatic shock absorber suspension
 福特野马外形依旧那么放荡不羁。宽大的上下前脸进气隔栅,有助于发动机的有效散热。全新福特野马的内饰完全进行了重新的设计,新车中控台中央增加了一个大尺寸的屏幕,下方按键的排列也有所调整。时尚的功能性的车内造型及其精确的制作工艺为劲车设计设定了新的标准。在一贯的肌肉车线条基础上,增加了许多弧型线条,使整车看上去更为刚毅、强壮,也更具视觉冲击力。美式肌肉车的经典之作——福特野马车型。
The Ford Mustang was still as wild as ever. The wide upper and lower front air intake grille is helpful for the effective heat dissipation of the engine. The interior of the all-new Ford Mustang has been completely redesigned. A large screen has been added in the center of the new car's central console, and the arrangement of the buttons below has also been adjusted. The fashionable functional interior styling and precise manufacturing process set a new standard for the design of Jinche. On the basis of the consistent muscle car lines, many arc lines are added to make the vehicle look more firm, strong and more visual impact. The classic of American muscle car -- Ford Mustang.
上面说了4点好处,其实啊,大多数车友是为了更好的趴低……车子低了对我们来说才是美,才有范儿。还能够享受周围人们的注目。
There are four advantages mentioned above. In fact, most of the riders want to lower themselves better The lower the car is, the better it is. You can also enjoy the attention of people around you.
空气减震的优势
Advantages of air shock absorption
Air damping is to use pure gas as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
