查看: 670|回复: 0
别克君威改装AIRBFT气动避震低趴案例分享
发表于 2020-7-17 12:48:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Case sharing of Buick Regal refitting airbft
改装玩家: 一低遮百丑 气动配合好轮毂的尺寸和数据可以把车降到最低。静止时,把车降到最低趴在地上,帅。行驶时,根据路况任意调节喜欢的高度。
不改装 日常代步车主: 你可以认为他是为了方便任意上下马路牙子。
很多女人说 好好的车干嘛要改 你也很美 干嘛要化妆
Refit player: one low cover hundred ugliness pneumatic matching wheel hub size and data can reduce the car to the minimum. When stationary, lower the car to the lowest, lying on the ground, handsome. When driving, adjust the height you like according to the road conditions.
Do not refit the daily car owner: you can think that he is to facilitate arbitrary up and down the road.
A lot of women say that a good car needs to be changed, and you are beautiful. Why make up
说到HellaFlush改装,HellaFlush不分车型,不分高低贵贱。不论HellaFlush风格改装从何而来,它都离不开气动避震的支持。
When it comes to the modification of hellaflush, hellaflush is regardless of the model and the high or low. No matter where hellaflush style modification comes from, it can not do without the support of pneumatic shock absorber.
