查看: 687|回复: 0
最美道奇挑战者精心打造改装气动避震低姿态诞生
发表于 2020-7-16 17:36:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most beautiful Dodge Challenger meticulously creates refitted pneumatic shock absorbers with low attitude
道奇挑战者,是由克莱斯勒推出的肌肉车类型(本来推出了普利茅斯鲶鱼,但考虑到品牌的知名度才推出了挑战者,后来普利茅斯鲶鱼转攻加拿大市场)。1970年推出第一代,2009年推出第三代。挑战者的出现虽然同样是为了向福特野马宣战,但它的投产却只有短短5年。在1970年到1974年间,挑战者共售出约188600辆。在今天,一辆精心保养还原的挑战者甚至可以卖得六位数美元的高价。
Dodge Challenger is a muscle car type launched by Chrysler (Plymouth catfish was originally launched, but it was only launched in consideration of the brand's popularity, and then Plymouth catfish moved to the Canadian market). The first generation was launched in 1970 and the third generation was launched in 2009. Although the challenger is also to declare war on Ford Mustang, it has only been put into production for only five years. Between 1970 and 1974, challengers sold about 188600 vehicles. Today, a well maintained and restored challenger can even sell for six figure dollars.
『气动减震器,能够轻易改变车身高度』李洋
