查看: 925|回复: 0
‘一马当先’福特野马改装AIRBFT气动避震低趴风格
发表于 2020-7-16 17:26:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mustang refits airbft aerodynamic shock absorber low lying style
野马在银幕上也出尽了风头,包括007影片《金手指》和《金刚钻》史蒂夫麦圭恩主演的《Bullitt》,以及《极速60秒》(1974的原版和2000年由尼古拉斯·凯奇主演的重拍片)。都有福特野马的身影。
Mustang also made big screen appearances, including 007 films "golden finger" and "Bullitt" starring Steve mcguinen in diamond, as well as "super 60 seconds" (the original 1974 version and the 2000 remake starring Nicholas Cage). Ford Mustang is everywhere.
在2014纽约车展中,福特发布了全新野马50周年限量版,并有望在2014年秋季上市。新车在诸多细节方面做出了调整,从而区分于普通版本的全新野马车型。
At the 2014 New York Auto Show, Ford released the new Mustang 50th Anniversary Limited Edition, which is expected to be available in the fall of 2014. The new car has been adjusted in many details to distinguish it from the new Mustang model of the ordinary version.
1: Main functions: four wheel independent lifting, front and rear independent lifting and overall lowering; adjustable air tank pressure, working setting of air pump, three-stage memory,Mobile phone app remote control, ignition automatic rise, automatic low prone, support Chinese, English and other languages, remote control panel with LCD display, mainTo display the 4-wheel air bag pressure value and cylinder pressure value, more safely to feel the air shock culture for you to bring car fun.
