查看: 910|回复: 0
丰田致炫改装气动避震低趴案例分享
发表于 2020-7-16 17:11:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
丰田致炫改装气动避震低趴案例分享
Case sharing of Toyota Zhixuan refitting pneumatic shock absorber
第一次看到气动避震改装的车子到现在深深陷入其中不能自拔,也是经历了很多的曲折!也学习到了不少关于气动避震改装的知识!
For the first time, I saw the car refitted with pneumatic shock absorber, and now I am deeply trapped in it and have experienced many twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge! Case sharing of Toyota Zhixuan refitting pneumatic shock absorber
