查看: 743|回复: 0
奔驰A200气动避震低姿态改装案例分享
发表于 2020-7-16 16:41:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奔驰A200气动避震低姿态改装案例分享
Case sharing of low attitude modification of Mercedes Benz A200 pneumatic shock absorber
说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!
Speaking of the low prone posture, the contribution to the steady landing of the car stems from the small gas tank in the trunk. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying! Low lying refit style has become a fashion, the body close to the ground makes it more inclined to run, cool appearance is very eye-catching, perhaps because it is different!
