查看: 728|回复: 0
Ford musrang改装AIRBFT气动避震悬挂 海拉风格魅力
发表于 2020-7-16 15:52:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford muslang refitted airbft pneumatic suspension Haila style charm
AIRBFT专用气囊:
Airbft special airbag:
空气减震的优势
Advantages of air shock absorption
Air damping is to use pure gas as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
