查看: 2062|回复: 0
美国正品ENDD-3加仑铝合金气罐 气动避震专用无缝高压储气罐
发表于 2020-7-16 15:45:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
American genuine endd-3-gallon aluminum alloy air tank, special seamless high-pressure air storage tank for pneumatic shock absorber
Pneumatic shock absorber is a kind of air suspension shock absorber installed on the car. Rubber air shock absorber is used to replace the spring shock absorber of the original car, so that the height of the body can be raised freely on the off-road Road, and the body can be lowered at high speed. The vehicle equipped with pneumatic shock absorber has good trafficability, and its shock absorption performance and comfort are much better than those of the original vehicle
