查看: 900|回复: 0
特斯拉Model3改装AIRBFT360C静音气泵气动避震姿态案例
发表于 2020-7-15 17:11:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study on the aerodynamic shock absorption attitude of Tesla Model3 refitting airbft360c silent air pump
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
气动避震这个昂贵的名字成了土豪的专用。
要控制气动,气动减震器会链接到车内,有一个控制器会控制它,高度也不是自己随意想按到哪个高度松手就可以的。
会根据高度来设定几个档位,在这几个高度切换。停车时,可以做到最低趴,几乎贴到地面,要行驶时,再抬高。
气动避震即使你不了解改装,但是想一想,能把车子随时做到升降的设想,总会做得到的,所以气动避震是改装界必然出现的产物。
Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
The expensive name of pneumatic shock absorber has become the exclusive use of local tyrants.
To control the pneumatic, the pneumatic shock absorber will be linked to the car, and a controller will control it. The height is not what height you want to press at will and release it.
It will set several gears according to the height and switch at these heights. When parking, you can reach the lowest position, almost stick to the ground, and then raise it when you want to drive.
Even if you don't know how to refit pneumatic shock absorbers, if you think about it, you can always do it if you want to lift the car at any time. Therefore, pneumatic shock absorber is an inevitable product in the refitting field.
