查看: 700|回复: 0
2020款AIRBFT气动避震悬挂正式推出 全新功能低趴新纪元
发表于 2020-7-15 16:38:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
2020 airbft pneumatic suspension officially launched a new era of low lying
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。这是可以控制车身高度高低的配置,随时变成低趴车,也能变成正常的高度。
听起来非常方便,气动避震到底是什么原理呢?
Like to play modified shock absorber system enthusiasts, air shock absorber is one of the most expensive topics. This is a configuration that can control the height of the body. It can become a low prone car at any time, and can also become a normal height.
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。气动避震这个昂贵的名字成了土豪的专用。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc. Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful. The expensive name of pneumatic shock absorber has become the exclusive use of local tyrants.
要控制气动,气动减震器会链接到车内,有一个控制器会控制它,高度也不是自己随意想按到哪个高度松手就可以的。会根据高度来设定几个档位,在这几个高度切换。停车时,可以做到最低趴,几乎贴到地面,要行驶时,再抬高。气动避震即使你不了解改装,但是想一想,能把车子随时做到升降的设想,总会做得到的,所以气动避震是改装界必然出现的产物。
To control the pneumatic, the pneumatic shock absorber will be linked to the car, and a controller will control it. The height is not what height you want to press at will and release it. It will set several gears according to the height and switch at these heights. When parking, you can reach the lowest position, almost stick to the ground, and then raise it when you want to drive. Even if you don't know how to refit pneumatic shock absorbers, if you think about it, you can always do it if you want to lift the car at any time. Therefore, pneumatic shock absorber is an inevitable product in the refitting field.
要选择合适的气动避震并不简单,气动避震的等级不同。品牌也是五花八门。目前市场上主要分两种气动方式,机械式气动避震和电子式气动避震,不用明说,光听见电子这两个字,就知道技术含量比较高。价格上,比机械式气动避震要高,但是稳定性上没有机械式这么可靠。气动避震是一件比较精密的配件,和原厂避震相比完全是一个天一个地。气动避震上各有一个弹性橡胶气囊,气囊其实是一个密闭的压力缸,里面充满了惰性气体和油气混合物。腔体内的压力要比大气压高几倍甚至几十倍左右,再利用活塞杆的横截面积小于活塞的横截面积,来产生压力差,使活塞杆运动。
因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度。
It's not easy to choose the right pneumatic shock absorber. The grades of pneumatic shock absorbers are different. There are also various brands. At present, there are mainly two kinds of pneumatic shock absorbers in the market, mechanical pneumatic shock absorbers and electronic pneumatic shock absorbers. Needless to say, just hearing the word "electronic", you will know that the technical content is relatively high. The price is higher than the mechanical pneumatic shock absorber, but the stability is not as reliable as the mechanical type. Pneumatic shock absorber is a more precise accessory, compared with the original shock absorber, it is completely one day a place. There is an elastic rubber air bag on the pneumatic shock absorber. The air bag is actually a closed pressure cylinder filled with inert gas and oil-gas mixture. The pressure in the chamber is several times or even dozens of times higher than that of atmospheric pressure, and then the cross-sectional area of the piston rod is smaller than that of the piston to generate pressure difference and make the piston rod move.
Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads. It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise, and the accuracy of pneumatic regulation will be lost.
