查看: 657|回复: 0
AirBFT气动避震堵头 304不锈钢G14堵头 带O型圈,安装方便,杜绝漏气,杜绝使用胶水
发表于 2020-7-15 16:26:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber plug 304 stainless steel G14 plug with O-ring, easy to install, prevent air leakage and use of glue
1: Main functions: four wheel independent lifting, front and rear independent lifting and overall lowering; adjustable air tank pressure, working setting of air pump, three-stage memory,
Mobile phone app remote control, ignition automatic rise, automatic low prone, support Chinese, English and other languages, remote control panel with LCD display, mainTo display the 4-wheel air bag pressure value and cylinder pressure value, more safely to feel the air shock culture for you to bring car fun.
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Cruz, etc! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
