查看: 714|回复: 0
凯迪拉克ATS改装AIRBFT气动避震经典低趴来袭
发表于 2020-7-15 16:04:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Cadillac ATS modified airbft aerodynamic shock absorber
凯迪拉克ATSL在外观上有着独具匠心的设计感,棱角分明的线条,大气的进气格栅,又大又亮的LED大灯。前脸不错看,同事最常夸赞的场地就是前脸,传神的卤素大灯,在白天行驶闪亮中带着运动的感觉。车尾造型协调,不失流畅与华丽,不过相比之下轮圈的款式就看起来有些平淡无奇。总之,个性鲜明的造型格调透漏着设计师无数个日夜的辛勤汗水,尽显工匠精神。
Cadillac ATSL has a unique sense of design in the appearance, sharp and angular lines, atmospheric air intake grille, and large and bright LED headlights. The front face is good. I can see that the venue most praised by my colleagues is the front face. The vivid halogen headlights bring a sense of movement when driving in the daytime. The rear styling is harmonious, smooth and gorgeous, but by contrast, the design of the wheel rim looks a little plain. In short, the distinctive modeling style reveals the designer's hard work for countless days and nights, showing the craftsman spirit.
