查看: 748|回复: 0
本田杰德改装AIRBFT气动避震悬挂 领略非凡魅力
发表于 2020-7-15 15:42:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda jade modified airbft pneumatic shock suspension to enjoy extraordinary charm
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
Oil was surging in the blood
If you are not so ordinary
气动避震改装现在在国内已经成为一种潮流,玩车的人几乎人人都知道气动避震,但由于价格和产品稳定性让很多人望而却步,价格高是因为我们为保证产品质量,多数的配件采用国外进口,但是说在使用过程中出现的一些质量问题主要是由三个原因引起,一是安装环节导致,气动避震一定要找专业的安装人员进行安装调教,否则会因安装位不准确对产品造成损害、二是没有正确的使用和保养、三也是最少见的,是产品配件自身出的质量问题,如气泵衰竭,电脑不稳定等因素。所以气动避震的安装使用一定要严格按照生产厂家的要求来进行安装。那么都有哪些车型可以改装气动避震悬挂,在国内AIRBFT气动悬挂应该是车型最全的一个品牌,几乎覆盖所有车型,新车也可快速开发定制,其实气动避震也就两部分,控制系统和避震!控制系统大概都是电子元件,避震是专车专用,唯独皮囊!心里障碍就在这里!气动避震是Vip或者Hellaflush风格里必不可少的元素,它的升降功能是这种低趴风格里不可缺少的,这就是气动避震悬挂的特殊之处。气压避震,通过改装四支“气压避震+控制器”从而达到在车内随意调节车身高度的目的,很多品牌高端配置车型也会有,它叫做“空气悬挂” 差别在哪?升的没气压避震高,降的没气压避震低,升降速度没气压避震快。通常超跑 高端suv顶配才有的配置。
Pneumatic shock absorber refitting has become a trend in China. Almost everyone who plays with cars knows pneumatic shock absorbers. But because of the price and product stability, many people are deterred. The high price is because we import most of the accessories from abroad to ensure the product quality. However, some quality problems in the use process are mainly caused by three reasons. One is safety Due to the installation process, we must find professional installation personnel for installation and adjustment. Otherwise, the product will be damaged due to inaccurate installation position. Second, there is no correct use and maintenance. Third, it is the most rare. It is the quality problems of product accessories themselves, such as air pump exhaustion, computer instability and other factors. Therefore, the installation and use of pneumatic shock absorber must be in strict accordance with the requirements of the manufacturer. In China, airbft pneumatic suspension should be a brand with the most complete models, covering almost all models. New cars can also be developed and customized quickly. In fact, pneumatic shock absorbers consist of two parts: control system and shock absorber! Control system is probably electronic components, shock absorbers are dedicated to special vehicles, only leather bags! Here is the mental obstacle! Pneumatic shock absorber is an essential element in VIP or hellaflush style, and its lifting function is indispensable in this low lying style, which is the special feature of pneumatic shock absorber suspension. Pneumatic shock absorbers, by refitting four "pneumatic shock absorbers + controllers" to achieve the purpose of adjusting the body height in the car at will. Many high-end configuration models of many brands also have them. What's the difference between them? The rising is not as high as the air pressure shock absorbers, and the falling ones are not as fast as the air pressure shock absorbers. Usually, the top configuration of super high-end SUV is available.
