查看: 1358|回复: 0
经典12代皇冠改装气动避震悬挂完美低趴案例介绍
发表于 2020-7-15 15:13:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study on the perfect low lying of the classic 12 generation crown refitted with pneumatic shock absorber suspension
受港剧的影响,很多人在很小很小的时候,皇冠就已经映入大家的眼中。在当时,对车并不了解,只知道这台车叫皇冠,以及它很贵。到后来,皇冠以进口的身份正式引进大陆市场,也顺理成章的成为了当时大部分有钱人的座驾。
Under the influence of Hong Kong opera, many people have already seen the crown when they are very young. At that time, I didn't know about the car. I only knew that the car was called crown and it was very expensive. Later, crown was officially introduced into the mainland market as an import, which naturally became the car of most wealthy people at that time.
气动避震改装的分类以及几个版本的区别和使用感受
The classification of pneumatic shock absorbers and the difference and use experience of several versions
气动避震的组成部分分为控制系统和气动避震桶身两大类!
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns!
Also learned a lot about pneumatic shock absorber refitting knowledge!
Intelligent air replenishment and intelligent adjustment of vehicle level: in fact, the functions of these two functions are the same. For example, the body height is originally horizontal. If a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change at the rear, and respond in less than one second. The two air bags at the back will be inflated to maintain it Body level!
点火自动升到设定的位置高度:这样一个功能就是不管你停车的时候是一个什么样的高度,比如说是最低或者是最高你停车,下车,再次开车的时候系统会自动的将车子升到2档的位置,也就是正常用车的高度!这样有好处也有坏处,比如说路况非常不好,没有合适的停车位置,停车的时候是在最高的位置停车,再次开车的时候系统就会自动的降低,如果你刚好停在一个很高的乡村水泥减速带上,那么很有可能或直接托底!好处就是在正常的停车场,停车车子降到最低,再次开车的时候一点火车子自动升到正常的行驶高度,想一下这个逼格有多高。
The ignition will automatically rise to the set position height: such a function is no matter what kind of height you park, such as the lowest or the highest, when you stop, get off, and drive again, the system will automatically raise the car to the second gear position, that is, the height of the normal car! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When parking, stop at the highest position. When you drive again, the system will automatically decrease. If you just stop at a very high rural cement deceleration belt, it is very likely to or directly support the bottom! The advantage is that in a normal parking lot, the parking car is lowered to the lowest level. When driving again, the train will automatically rise to the normal driving height. Think about how high this force is
