查看: 765|回复: 0
气势非凡宝马E66改装AIRBFT气动避震悬挂
发表于 2020-7-14 16:45:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Extraordinary momentum BMW e66 refitting airbft pneumatic suspension
低趴风潮被越来越多群众认识,走过路过的朋友都拿起了手机一顿拍照,不过,不少吃瓜群众嘴里依然有疑问:这些车子这么低趴,怎么开上路的呢?在此建议主办方:不妨制作大型海报,设置展示区域,科普Hellaflush文化和气动避震器工作原理,我想群众们会更加受益。
More and more people are aware of the trend of low lying down. All the friends passing by picked up their mobile phones to take pictures. However, many gourd eaters still have doubts: how can these cars go on the road when they are so low? I suggest that the organizers: make large posters, set up exhibition areas, popularize hellaflush culture and the working principle of pneumatic shock absorbers. I think the masses will benefit more.
空气悬架的优点
空气悬架系统是以空气弹簧为弹性元件
利用气体的可压缩性实现其弹性作用的
压缩气体的气压能够随载荷和道路条件变化而进行自动调节,
不论满载还是空载,整车高度不会变化
可以大大提高乘坐的舒适性。
Advantages of air suspension
Air suspension system takes air spring as elastic element
Using compressibility of gas to realize its elastic action
The pressure of compressed gas can be adjusted automatically according to load and road conditions,
No matter full load or no load, the vehicle height will not change
It can greatly improve the ride comfort.
Because of its unique performance and adaptability, air spring suspension is gradually entering the field of traditional steel plate and coil spring.
空气弹簧的运动性能特点是:
负载能力可调;
弹性系数随负载变化;
负载变化肘,固有频率几乎不变;
固有频率较低。
The movement characteristics of air spring are as follows:
The load capacity is adjustable;
The elastic coefficient varies with the load;
When the load changes, the natural frequency is almost unchanged;
The natural frequency is low.
这些特点决定了空气悬架具有以下优点:
(1)乘坐更舒适安全;
(2)改善车辆的行驶平顺性;
(3)延长轮胎和制动片的使用寿命;
(4)负载变化时车身高度不变;
(6)减少对道路的冲击,保护路面,降低高速公路的维修费用;
(7)延长车辆的使用寿命并增加折旧值
These characteristics determine that air suspension has the following advantages:
(1) Ride more comfortable and safe;
(2) Improve the ride comfort of vehicles;
(3) Extend the service life of tires and brake pads;
(4) When the load changes, the body height remains unchanged;
(5) Reduce the maintenance cost of electrical, air conditioning, exhaust system, axle, body and chassis;
(6) Reduce the impact on the road, protect the road surface and reduce the maintenance cost of expressway;
(7) Extend the service life of the vehicle and increase the depreciation value
