查看: 803|回复: 0
宝马3系F30气动避震改装 AIRBFT气动避震低姿态案例
发表于 2020-7-14 16:03:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Low attitude case of modified airbft pneumatic shock absorber for BMW 3 Series F30
说起豪华品牌中级车,相信有不少朋友都会第一个想到宝马3系。的确,近期上市的第七代3系也是最近非常热门的车型。在全新3系发布时,宝马特意强调了3系一直是宝马家族中最为重要且最畅销的车型。
Speaking of luxury brand intermediate cars, I believe many friends will be the first to think of BMW 3 series. Indeed, the recently launched seventh generation 3 series is also a very popular model. At the launch of the new 3-series, BMW specially stressed that the 3-Series has always been the most important and best-selling model in the BMW family.
So, what is pneumatic shock absorbers? The working principle of pneumatic shock absorbers is to change the height of the car by controlling the air pressure, so as to improve the trafficability of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think how the car can be so low! In recent years, car riders often talk about "one low cover three ugliness", and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
