查看: 930|回复: 0
丰田14代皇冠改装AIRBFT气动悬挂 Hellaflush风格低趴风
发表于 2020-7-14 15:24:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota 14th generation crown modified airbft pneumatic suspension hellaflush style low lying wind
现在一提到成功人士的座驾,大家总会下意识地想到宝马,但是你可知道,在上世纪80年代,宝马还没有大规模地进入国内市场,那些抢先一步富起来的人买的第一台车是什么牌子才能突显自己的身份,没错就是丰田家族的皇冠。
Nowadays, when it comes to the cars of successful people, people always think of BMW subconsciously. But do you know that in the 1980s, BMW did not enter the domestic market on a large scale. What brand of the first car that those who got rich first could highlight their identity. Yes, it was the crown of the Toyota family.
