查看: 730|回复: 0
高端大气上档次12代皇冠成功改装AIRBFT高度尺皮囊避震
发表于 2020-7-14 15:02:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The 12th generation crown of high-end atmosphere is successfully refitted with airbft height scale leather bag for shock absorption
六十多年前,皇冠第一次踏上中国大陆,是国内第一台丰田进口汽车,往后六十余年里丰田汽车在中国市场取得的所有成绩,正是由皇冠这台汽车拉开帷幕,而“车到山前必有路,有路就有丰田车”这句广告词早已深入人心。有些人说12代之后再无皇冠,说法虽然有些片面,但也侧面证明12代皇冠在很多方面做得确实出色。不管是玩姿态还是玩竞技,12代皇冠都从容不迫。
Some people say that there will be no crown after the 12th generation. Although it is one-sided, it also proves that the crown of the 12th generation is indeed outstanding in many aspects. Whether it is playing posture or playing sports, the 12th generation crown is calm.
AIRBFT专用气囊:
Airbft special airbag:
