查看: 731|回复: 0
宝马E60改装AIRBFT气压避震低趴案例
发表于 2020-7-13 14:28:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW E60 modified airbft pneumatic shock absorber low prone case
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
避震方面,还是一步到位, 台湾正品新款AIRBFT三段记忆版本控制: 四轮独立升降、前后独立升降、整体下降;气罐压力可调,打气泵工作设定,三段记忆,手机APP遥控,点火自动升高,熄火自动低趴,支持中,英文等多种语言,遥控面板自带液晶显示屏,主要显示4轮气包气压值和气瓶气压值,更加安全的去感受气动避震文化为您带来的用车乐趣。32段阻尼软硬可调避震器,采用V360高功率超静音打气泵充气速度更快更安静。采用AIRBFT专用皮囊,无论是操控性能还是舒适性能都达到了同级别的最佳效果。电磁阀组:新款阀体表面采用拉丝处理,更加提高了产品的整体质感。   安装问题:安装简单方便,操作简单易懂。 产品优点:方便配合任何一款避震使用,通用性高,可以任意搭配组合,方便做精美的后备箱造型
In terms of shock absorption, it is still in place in one step. Taiwan genuine new airbft three segment memory version control: Four wheel independent lifting, front and rear independent lifting and overall descending; air tank pressure adjustable, air pump working setting, three segment memory, mobile phone app remote control, ignition automatic rising, flameout automatic low lying, supporting Chinese, English and other languages. The remote control panel is equipped with LCD display, which mainly displays 4-wheel air bag pressure value and gas cylinder pressure value, so as to feel the pneumatic shock absorber culture for you more safely Car fun. The 32 stage damping soft and hard adjustable shock absorber adopts V360 high-power ultra quiet air pump to charge faster and quieter. With airbft special leather bag, both the handling performance and comfort performance have reached the best effect of the same level. Solenoid valve group: the surface of the new valve body adopts wire drawing treatment, which improves the overall texture of the product. Installation problem: the installation is simple and convenient, and the operation is simple and easy to understand. Product advantages: easy to use with any shock absorber, high versatility, can be combined with any combination, convenient to make a beautiful trunk shape
After refitting the pneumatic shock absorber, it is more fashionable and cool. When driving normally, you can freely choose the height of your car according to the different road conditions. If you lie down to the bottom during the Party of friends, I believe it will attract more attention for you. In case of bad road, improve the height of the body and enhance the trafficability of the body. The use of the air suspension system is the history of the production of pneumatic shock absorbersThe oldest manufacturer, quality and stability more worthy of your trust!
