查看: 811|回复: 0
福特野马改装气动避震低姿态 肌肉车的低趴效果鉴赏
发表于 2020-7-12 17:33:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Appreciation of low lying effect of Ford Mustang refitted pneumatic shock absorber low posture muscle car
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。这是可以控制车身高度高低的配置,随时变成低趴车,也能变成正常的高度。听起来非常方便,气动避震到底是什么原理呢?
Like to play modified shock absorber system enthusiasts, air shock absorber is one of the most expensive topics. This is a configuration that can control the height of the body. It can become a low prone car at any time, and can also become a normal height. It sounds very convenient. What is the principle of pneumatic shock absorption?
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc. Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
气动避震这个昂贵的名字成了土豪的专用。要控制气动,气动减震器会链接到车内,有一个控制器会控制它,高度也不是自己随意想按到哪个高度松手就可以的。
The expensive name of pneumatic shock absorber has become the exclusive use of local tyrants.To control the pneumatic, the pneumatic shock absorber will be linked to the car, and a controller will control it. The height is not what height you want to press at will and release it.
