查看: 975|回复: 0
“君临天下越重四海”别克君越改装AIRBFT气动避震低趴案
发表于 2020-7-12 17:06:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The case of Buick Regal refitting airbft with aerodynamic shock absorber
君者,君王、大丈夫,软弱一点的称呼:君子。多数情况下属于男性,是强者的称谓。通用希望他能真正展现了君王的威风。
Gentleman, king, husband, weak address: gentleman. In most cases, it belongs to the male, which is the appellation of the strong. GM hopes that he can really show the power of the king.
别克君威(Regal)是一部别克中高档轿车,定位介于英朗和君越之间,其时代感的外形,人性化的精致内饰及豪华的高科技配置,充分体现对成功领导人士的尊重;别克君威特有的V6强劲动力和宁静顺畅的驾乘感受满足了他们对商务座驾的高度要求。
Regal is a Buick medium and high-end car, positioned between yinglang and lacrosse. Its modern appearance, humanized interior and luxurious high-tech configuration fully reflect the respect for successful leaders. Buick Regal's unique V6 strong power and quiet and smooth driving experience meet their high requirements for business driving.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.
