查看: 808|回复: 0
奥迪A7改AIRBFTR线束装T空气避震低趴案例分享
发表于 2020-7-12 16:31:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi A7 modified airbftr wiring harness installation t air shock absorber low lying case sharing
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
作为同样喜欢改装车的你,不知道《速度与激情》系列给你有多大的影响。而对于WB来说,从速1到速8,还有速9的预告片,看了不少于20次。当然还有其他的,如《极品飞车》,《头文字D》,《湾岸MIDNIGHT》等等。因为每一次的重温,都会给WB带来动力,带来启发,生活色彩更丰富!
Oil was surging in the blood
If you are not so ordinary
As you also like refitting cars, I don't know how much influence the "speed and passion" series has on you. For WB, from speed 1 to speed 8, and speed 9 Trailer, I watched it no less than 20 times. Of course, there are others, such as "top flying car", "headword D", "Bay coast midnight" and so on. Because every time we revisit it, we will bring motivation and inspiration to WB and enrich our life!
