查看: 772|回复: 0
丰田坦途改装AIRBFT气动避震气囊大大提高承受力
发表于 2020-7-9 17:44:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota tanto refits airbft pneumatic shock absorber airbag to improve bearing capacity
丰田坦途(丰田Tundra)是一款很适合长途旅行的代步工具,它受到一度追捧的原因在于它的多功能性--集合了SUV的越野性能、卡车的载货能力、以及轿车的舒适性。
Toyota tundra is a very suitable vehicle for long-distance travel. The reason why it has been popular for a long time is that it is multi-functional, which combines the off-road performance of SUVs, the loading capacity of trucks, and the comfort of cars.
