查看: 943|回复: 0
运动豪华宝马G28气动避震悬挂改装完美成功案例
发表于 2020-7-9 17:30:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect successful case of refitting sports luxury BMW E38 pneumatic suspension
众所周知,宝马G28是宝马民用车型中运动属性最强的,几乎与生俱来就贴着一张“运动”的标签。确实,对于喜欢运动车系的车迷来说,宝马G28是一种重要的仪式感。因为宝马作为运动型四门轿车的标杆之一,将是这一领域未来几年的风向标。但是当新一代G28正式投产,宝马在保留运动属性的同时,贴上了一张新的标签——“豪华”。因此宝马G28被定义为:-运动豪华
As we all know, BMW G28 has the strongest sports attribute among the civil BMW models, and is almost born with a "Sport" label. Indeed, for sports car fans, the BMW G28 is an important sense of ceremony. As one of the benchmark of sports four door sedan, BMW will be the wind vane in this field in the next few years. However, when the new generation of G28 was officially put into production, BMW kept its sports attributes and attached a new label - "luxury". Therefore, BMW G28 is defined as: - Sports luxury
The car's shock absorbers are more comfortable than the original shock absorbers. They can be installed on the car's body at high speed. The air shock absorbers can be installed on the car's body to make it more comfortable. The air shock absorbers can be installed on the car's body at high speed. The air shock absorbers can be installed on the car's body to make it more comfortable than the original shock absorbers.
