查看: 743|回复: 0
奥迪A5B9改装AIRBFT气动避震悬挂案例介绍
发表于 2020-7-9 17:00:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study of Audi a5b9 refitting airbft pneumatic suspension
4: What do you need before refitting, what do you need, how do you want to play, and whether you want the effect after installationConvenience in use
