查看: 722|回复: 0
奥迪R8改装AIRBFT气动避震悬挂案例介绍
发表于 2020-7-8 17:51:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case study of Audi R8 refitting airbft pneumatic suspension
4: What do you need before refitting, what do you need, how do you want to play, and whether you want the effect after installationConvenience in use
