查看: 841|回复: 0
时尚改装风”十代思域改装空气避震悬挂低趴风格
发表于 2020-7-8 16:02:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of civic modified air suspension low lying style
"思域一改装,新郎穿西装",思域系列车子,就像美人坯子一样,稍稍化妆,就会有天翻地覆的变化。改装后的思域,就像高级跑车一样雷厉风行,清新的外观,配上湛蓝的天空,绝对称得上是一道亮丽的风景线。
"Once the civic is refitted, the groom will wear a suit." civic series cars, like the beauty body, will have earth shaking changes with a little make-up. The modified civic, like a high-end sports car, is as vigorous as a high-end sports car. With its blue appearance and blue sky, it is definitely a beautiful scenery.
既然说起本田思域,大家印象应该都是很深刻的,因为这款是在我国车友心中,还是有很大地位的,而且大家也非常喜欢这款车,最近的本田思域的新车型也已上市, 要马上跟大家见面了。
Since speaking of Honda Civic, everyone should be very impressed, because this model is in the hearts of our car friends, still has a great position, and we also like this car very much. The latest Honda Civic new model has also been on the market, and we will meet you soon.
