查看: 736|回复: 0
新款宝马3系AIRBFT空气避震改装案例 低趴风格魅力的展现
发表于 2020-7-8 15:24:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
新款宝马3系AIRBFT空气避震改装案例 低趴风格魅力的展现New BMW 3 series airbft air shock absorber modification case low lying style charm
相信每位拥有宝马的车主,心中都有一颗赛车的梦,有梦就要去追,改改更怡人。外观改装其实见仁见智,每个人都有自己的审美。宝马新3系,高颜值,足够运动,足够豪华,当然,买新3系的人不会忘了要进行改装了。
I believe that every owner of BMW has a racing dream in his heart. If he has a dream, he has to go after it and change it more pleasant. In fact, different people have different opinions on appearance modification. Everyone has his own aesthetic. BMW's new 3 series has high appearance, enough sports and luxury. Of course, people who buy the new 3 series will not forget to refit it.
汽车逐步走进了每个家庭,已经成为生活中最亲密的伙伴,
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
The car has gradually entered every family and has become the most intimate partner in life,
气动减震器的工作原理就是通过控制气压来改变车身高低,其包括弹性橡胶气囊减震器、气压控制系统、后备箱储气罐和电子控制系统等。
The working principle of pneumatic shock absorber is to control the air pressure to change the height of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system.
1: 一款好的气动避震品牌,那就是一个优质厂家,一个完整的质保售后服务体系
1: A good pneumatic shock absorber brand is a high-quality manufacturer and a complete after-sales service syste
